Video Settings Don't Save For RCA, Must Reset Them Everytime
I have a PS3 that refuses to use RCA cables consistently. I have to do the memory reset every time I turn on the PS3. I usually have to do it repeatedly for THAT to even work. Usually takes at least 10 minutes or sometimes more - leaving the system on seems to help. EVENTUALLY it gives. I get the reset menu. I don't need to adjust anything; at that point all I need to do is restart the system.
I don't have anything with an HDMI port or related cable to test if it works with such a source while I get the black screen. However, I do get audio through the RCA L/R jacks.
I came to the conclusion that it was probably the PRAM battery. It does not appear to be the case. I have replaced it once. There is an off chance that the new battery was already dead, but that seems unlikely. It did not fix the problem.
Any additional thoughts or suggestions would be appreciated. Thanks in advance.
Это хороший вопрос?
1 Комментарий
I don't think this pertains to the following question, at least on the information provided: Why doesn't my PS3 have a signal on my TV?
из Dranore
