This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314вопросов Показать все
Top screen has patchy red discoloration that moves?
The top screen on my DS Lite has developed an issue where usually the top part of the screen (or sometimes all of the screen) will develop a red tinge and turn all the colors on the screen more red. I don't think the screen is necessarily damaged because if I tilt the screen forwards or backwards it can either get better or worse (more of the screen turns red or less, sometimes even none if I tilt it just right). Is it some kind of connection in the hinge or something along those lines?
Thanks.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
That tends to happen if the backlight is beginning to fail. Moving it may help some but eventually it will fail completely.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
That usually happens when's the screen is stepped on.
из
Добавьте свой ответ
Taylor Whitney будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 466
