Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
198вопросов Показать все
TV Screen Won't Turn On, Sound Still Works
I bought an LED tv awhile back, unfortunately the screen was scratched the day I bought it but was on a deal so I had to get it. Had it for a couple years, approximately 3, and then I gave it to my mom. She had it for a good while and then the screen went black recently but the sound still worked so I'm trying to help her fix it. I know a little about technology so I can narrow it down to a few things I think might be wrong with it which would either be the capacitors, the backlight, or transmitter I believe. I'll update with more information later. This is all I know at the moment, we're states away and I have a busy schedule so it takes time for me to get in touch with her. So if anyone can help please stay tuned, thank you.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
if the back-lite is on then this is most likely a tcon issue.
if the panel is dark no backlite then this could be a few things
1st if no backlite dark panel disconnect the wire harness between the main board and power supply. Now plug the set in...that should force the backlite on---if it does not come on the you have either a panel or power supply isse
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
KP будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 566
