not charging nor detecting charger.
Doesn't detect charger connection. Battery is full discharged. Random flicker of the screen as if accepting charge. Then nothing including battery is being xharged
Это хороший вопрос?
Это хороший вопрос?
Are you using the original charger? These devices don't like charging from flat otherwise. Another possibility is that the battery has dropped below the 0% mark (3.7v), This is fairly common if it has been left sitting in a flat state
Был ли этот ответ полезен?
I've heard around that to fix this is to open up the tablet then unplug and plug the battery connector to fix this problem.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 99
Did you try a different charger?
из Joel
