Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
5079вопросов Показать все
Replaced lightning connector, now phone won't charge at all
Was having issues with phone charging. Would have to wiggle the cable around until I found a spot that would charge and if I move the cable it would disconnect. So I replaced the connector, the audio jack works and speaker works though nothing happens now when I try to charge. Also replaced the battery at the same time.
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Hard to say. Likely one of these parts is not working. What you're going to have to do, is exchange them, and find which one is the problem. Lucky thing is, guessing because you changed them both out, you wanted them both to be changed. If you had a voltmeter, you could determine if the battery was the issue
Был ли этот ответ полезен?
Оценка 1
Комментарии:
I have put the old battery back in and still same issue.
из
Ok, so I would think that the new lightning dock is the issue then. You can likely exchange it and get a new one. Sometimes parts just come out of the factory broken
из
Also dry fit the new lightening connector before you install it, connect the connector to the motherboard and lay the lightening connector to the right of the phone and plug in using original apple charger. This way you can make sure the phone is charging and working before you go through the work of the install only for it not to work.
Оценка 1
Probably a stupid question considering the forum, but 19/20 of our customers looking to replace the charging port only have dusty/filthy ports. Have you tried cleaning your original charging port with a tweezer?
Оценка 0
Добавьте свой ответ
Jack будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 185
