First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
70вопросов Показать все
Dent in rear case
Any experience getting a dent out of the rear casing? Have a small dent I would like to get out. It is located on the rear case directly beside, maybe slightly behind the communications board on my 3G. I think I can get to it fairly easily, but curious what tool you might use to pop or push the dent back out?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
I would take it apart, here's how: iPad 3G Repair
and put it on a hard flat surface and burnish it from the back with a piece of smooth stainless steel. A small bar of steel works and I've used dental instruments for small jobs rubbing back and forth. Practice on something else first till you understand burnishing. Here's a site that might help you: http://www.votawtool.com/zcom.asp?pg=pro...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Brad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 4,541
