Первая модель iPhone. Модель А1203; с 4, 8 или 16 ГБ памяти; и алюминиевой задней крышкой. При ремонте придется помолиться и немного попаять.
224вопросов Показать все
does not power on neither is detected by USB
My iPhone is black, does not seems to power-on neither is detected by USB, should this to be a problem with logic board or communication board?
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
If it doesn't boot at all, and a computer won't recognize it, all signs point to logic board.
Sorry (but good job in narrowing down possible parts)!
Был ли этот ответ полезен?
Оценка 0
hi guys i have the same problem i did charge it in my car and it stop working and now is dead!!!!!! and i would like to know were i could repair the power part for my phone and wish parts I have to replace!!!
Thanks guys !!!!
Оценка 0
1 Комментарий:
please start your own question, it makes it easier to handle and we can prevent any mixups
из
Not sure if it's worth it, but I had a similar issue.
While charging in my car charger (I just purchased a Griffin) the entire phone went dead. When rebooted the backlight would not work, I tried brightness auto/off settings with no result, the screen would work when connected to usb. I restored it and the issue became a flickering backlight but lost it's ability to charge.
No matter where I plugged it it refused to charge. It is now dead and will not respond to anything hard reset or otherwise.
Оценка 0
Добавьте свой ответ
alexfrnds будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,731
