Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4982вопросов Показать все
My iPhone 6 has lines and black spots all over the screen
So I dropped my phone this morning and the screen slightly popped off so I pushed it back in and there are lines that around colorful and are horizontal and vertical are all over my phone. And when a press on it the lines change and there is a huge black spot too. Do I just get the screen fixed? Is there also something wrong with the motherboard too? please help me out
Update (02/23/2016)
These are pictures of how my phone looks too
Это хороший вопрос?
Оценка 18
Добавить комментарий
5 Ответов
Выбранное решение
Is the phone functional in all other ways camera, app functions, music play . Test it for function . Does it seem to be running warm or hot or differently in any way . if all seems fine except the screen odds are that you can replace the LCD and your phone will be fine . There is also the off chance that the cable has been partially dislodged and reconnecting will fix the problem but most likely the LCD is damaged . Hope this helps
Был ли этот ответ полезен?
Оценка 6
5 Комментариев:
After seeing the photos you posted it looks like testing functionally is not an option. but I would still replace the entire display . If it doesn't work you can always resell the display on ebay
из
Thank you so much for helping me out! This has happened to me before too but the screen wasn't so bad. I really appreciate it!
из
I have the same thing with my iPhone 6s it has the lines and yellow and black dots but the black is covering the yellow dot. I don't know what to do about fixing it. My iPhone is not ready yet for a up grade for a new phone. It is hard to read my text massages. I don't want my iPhone 6s to dietary all. What should I do about my iPhone 6s? I am haveing trubal seeding the pitcher of my iPhone 6s what it looks like know.
из
my phone has coloured lines and black patches but i cant use my screen at all and it disabled my phone too
из
Thank you this happened to my phone too however i can still use the phone, will the lines and the black dots grow, will the problem get worse or can i just leave it? thanks
из
Наиболее полезный ответ
Probably the front panel needs replacement. You have guide here on IFIXIT, good luck!
Оценка 7
3 Комментариев:
Thank you for helping me out :)
из
I think am gating a Prepay phone. Unttill my iPhonere 6 is ready for a upgrade to get a new Smaert Phone or something els I don't know yet.
из
This was a very unhelpful answer, selling it just like that is unhelpful and useless
из
Hi i recently dropped my iphone 6 like the picture showing i have lines on my phone and black dots but i also keep getting a message on the home screen there is a sensor issue with the phone but its responding to my touch only on the bottom half of my screen the home button has stopped working before i dropped the phone and i cannot unlock my iphone because my passcode has numbers at the top of my screen, will replacing this screen fix the issue as the screen is completly cracked and parts of the screen are missing at the top ?
Оценка 2
1 Комментарий:
I have this problem on my phone too what shall i do?
из
So i dropped my iphone and know i can’t even get into it cause there is black spread all around my phone and on the top half of the phone there is vertical lines then on the bottom half it’s just glitching out and idk what to do with it. Do any of ya’ll know what to do?
Оценка 1
my phone is the exact same as the image after i dropped it. if i get this repaired will i lose my data
Оценка 0
Добавьте свой ответ
Amrin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 47
За последние 30 дней: 181
За всё время: 96,044
