6th generation Android smartphone designed by Google and manufactured by Huawei. Released October 2015.
Nexus 6p screen scratched
I scratched my screen 6p nexus in the technical service of huawei they change the LCD screen + Frame + 188 € but in my case is only scratched the screen. they can change only the glass and make cheaper repair?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (4)
Выбранное решение
While it is technically possible for them to replace only the glass it would be more time consuming than it is worth. Since the glass and lcd are bonded on most phones, replacing only the glass would require then to separate the panels and reglue a new piece of glass. This can end up breaking the LCD and when it does work the results usually are not as good as new. In the end it is more reliable for a big company just to replace the whole unit, however if you were to replace the glass yourself you could save some money. From someone who has replaced the glass only on a galaxy note 2 though, I would say it isn't worth it if you are going to be using the phone as your daily driver.
Был ли этот ответ полезен?
Оценка 2
legofiend96 is right, well, you may buy a replacement online and have someone to repair it for you, that would be cheaper than sending it to Huawei service.
Replacement: http://www.etradesupply.com/huawei-nexus...
Tutorial: https://www.youtube.com/watch?v=PdWR7cU0...
Оценка 1
Baking soda can serve as a handy phone scratch remover. Here's how this remedy works:
  • Mix two parts baking soda and one part water in a bowl.
* Stir until it forms a thick paste.
* Apply the paste to a clean, soft cloth and gently rub in a circular motion on the phone's scratches.
* After this, wipe your screen with a fresh, slightly dampened cloth to remove any excess.
iPhone App Development Los Angeles
Оценка 0
PSD to WordPress, We Deliver high Quality Conversion Services to Our Clients.
Оценка 0
Добавьте свой ответ
frankytf будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 2,594
