Won't run on known GOOD batteries. Works only on AC
Hi, I have 2 G4 15" 1.67ghz low res laptops. One runs fine and charges and runs on both batteries. The "bad" laptop will ONLY work if it is plugged in, even if one of the good batteries is used. I've tried all the usual things like pram/pmu resets etc but nothing works. The bad laptop also fails to charge either of the batteries although it does"RECOGNIZE" the good batteries in System Profiler.
Does this mean a bad DC & SOUND card is the problem or is there something else that could be at fault?
Thanks!
Это хороший вопрос?
Оценка -1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
I would replace the battery connector. Here's how: PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector Replacement
Apple part # 922-6010 Here: [связанный продукт отсутствует или отключен: IF154-067]
also the DC cable:
[связанный продукт отсутствует или отключен: IF154-024]
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thank you so much. I appreciate your help. I was told at another site that it was the logic board, but I had my doubts. I've relied on this site for instructions on how to replace the logic board on another powerbook and now I realize I should come here for advice as well!
Оценка 0
1 Комментарий:
You accepted your comment not the answer.
из
I would like to change your laptop battery can replace it? How to be a kind of operation?
LG Latop Battery
Оценка 0
I am sorry, I don't understand your response/question Chinby. Can you try saying it a different way. If you are suggesting I should replace the batteries that is not correct. The batteries are good.
Оценка 0
Добавьте свой ответ
curtispsf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,040
