Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
31вопросов Показать все
Why am I not getting a full cup of coffee?
I have been pressing the large coffee option, but when the coffee is done brewing my cup is less than halfway filled!
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Check to see if your k-cup is seated correctly in the chamber. It may just be out of position and the needle located where the k-cup is placed is not puncturing the device properly.
The needle of your Keurig may also be clogged with coffee grinds and gunk, you should clean it off with a cotton swab if the problem persists.
Check out this troubleshooting guide if you need more assistance.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
@abornemann what needle? Where is it located? How do I clean those? Why would a clogged needle cause this?
из
Наиболее полезный ответ
@rosiecheeksxoxo I do realize that this is an assignment but if your Keurig would really have those symptoms, follow this guide to show you what and how to clean. Slightly different model, same principle.
Оценка 4
My coffee not coming out at all it's just clicking
Оценка 0
Добавьте свой ответ
Michelle Sanchez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,204
