The Toshiba Satellite C655-S5212 is a 15.6-inch laptop computer produced by Toshiba as part of the Satellite line of laptops.
6вопросов Показать все
My Toshiba laptop is making a loud whirring noise. What causes this!
It's made the noise before but usually gets better and quiets down. Is it the fan? Doesit need cleaning? If so, how do I clean it?
Это хороший вопрос?
Оценка 5
Добавить комментарий
3 Ответов
Выбранное решение
Hi,
its probably clogged fan so cleaning would be the best option
take a look at this youtube video (credits to the author): https://www.youtube.com/watch?v=f-9DTj8a...
it might help :)
Regards,
Kris
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
don't stop there Kris explain how to clean the fan
из
updated with video guide :)
из
I was having that problem also. I have a Toshiba Satelite that’s a few years old. After taking the back off (there are screws hidden beneath the pads closest to the hinge) I figured out that although the fan was clean it would sometimes hit against the fan housing when it spun at certain speeds. Instead of a gentle whir it was really loud. I fixed it by repositioning a silver pad that was stuck to the case a couple of inches from the fan so that was centered over the fan. The slight pressure between the fan and the case seems to keep the fan from hitting the housing.
Оценка 0
جهازي كان يصدر صوت طنين عالي وبعدها اعمله اعاده تشغيل ويذهب الصوت
الان لم يعمل الجهاز شاشه سوداء لكن اضواء الواي فاي والبطاريه تعمل كيف يتم اصلاحه
Google Translation
My device was making a loud buzzing sound and then I restarted it and the sound went away Now the device does not work, black screen, but the Wi-Fi lights and the battery are working, how to fix it
Оценка 0
2 Комментариев:
Shams Alali what device is this? What have you checked?
из
Fujitsu sprmobil v5666
из
Добавьте свой ответ
jvgomodern будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 30
За всё время: 16,305
