Can't bootup..stuck grey screen
I could go to openfirmware mode, and also I could use mac os 10.5 CDs to proceed to a certain point where "cannot be installed on this computer" comes up... at this point, I could use disk utility to at least see my HD model/serial number, but it says not mounted.
So my question is,
based on the above symptom, what's the likelihood of this being a logic board failure?
(I'm asking this question because I've tried swapping to a new hard drive and the same "cannot be installed.." message came up).
If diskutility at least identifies my HD, is my logic board OK?
Thanks in advance for any advice.
-genius bar sucks
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Format the hard drive with disk utility. Now install the system.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Добавьте свой ответ
Albert Kim буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 885
