Phone was bent, now will not power on
Hello.
I was asked to take a look at an iPhone 6 that became bent and will now not power on.
I've opened the case, removed the heat shield from the display cables, removed the display assembly, battery bracket, and SIM.
I've gently propped up the logic board to prevent any contact with the bent case.
Unfortunately, even with the lightning connector and batter connector still attached, it shows no signs of life with a hard reset, power button, plug into USB or with a wall charger.
Thoughts?
Это хороший вопрос?
1 Комментарий
Hi and thank you for responding. It is not recognized by iTunes. The angle of bend is not dramatic. My thinking was to eliminate any stress or short. The owner would like to retrieve the photos if possible.
из Captain Napalm
