Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
212вопросов Показать все
Fix "Error 6" while updating to iOS 9.3
So, a friend gave me her iPad Air 2 wifi with iOS 8.1 and I tried to update it using iTunes... it worked fine at the beginning but then it got stucked in a part when iTunes says "waiting for the ipad"...the ipad screen show's the progress bar but nothing happens then after a while iTunes displays a message saying that and Unknow Error has ocurred: error (6).
I've tried everything, becaused I readed online that the error is because iTunes can't reach the apple servers, however at the same time I was connected to the appstore downloading and updating apps so that's not possible.
I downloaded the firmware again, tried in another PC, tried in a MAC, tried in another place with different internet settings,
So, I don't know what else can I do. The iPad is completely new. I used the original usb wire. And like I said it was running iOS 8.1.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the iPad is still in warranty, I'd send it to apple. Get your friend to get a replacement for you as it would be under her name.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I live in Cuba so that's not an option
из
Добавьте свой ответ
Sl4sh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 757
