Small, easily transportable laptop released in 2012. The Gateway LT4004u is best equipped for simple uses, including web browsing and typical office or school applications.
3вопросов Показать все
Вопрос закрыт
Why do my keys keep sticking?
A couple of the keys on my keyboard keep getting stuck! If I jiggle them enough, they normally come back up, but it's really impacting my use of the computer. Can someone help me fix it so that they don't get stuck in the first place? Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
First, remove the key from using the steps on the Troubleshooting page. Then clean beneath the key and place the key back into place.
Был ли этот ответ полезен?
Оценка 0
I spilled a couple ounces of beer on my keyboard, and I turned the board over to let the moisture drain out and left it that way for several hours. A couple days later some of the keys were sticky. My research online to fix the problem showed that a keyboard can be disconnected and sprayed with water, then left upside down in a dry environment to dry out. Several suggestions even said a dishwasher was an easy fix, but that seems like overkill and I would worry about the heat effect; I wouldn't try that unless I was ready to buy a new keyboard anyway. That said, I did nothing and the keyboard work adequately , although a couple of the keys sometimes get a little sticky in humid weather.
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 98
