My iPhone 3G is dead after I opened the case
Hi
Two months ago, my iPhone 3G dropped into the water for 1 second. I dried it, I opened it (many times, so I've experience in opening and disassembling it) and cleaned it. Some strips on the display flex were damaged so I repaired them and the iPhone was alive again.
I used it normally for a month and a half and the last week I decided to replace the repaired flex with a new one. I bought the part, I opened the iPhone again, I replaced the flex (which is located in the display half), I closed it again and the iPhone never started.
Now it is completely dead. No display, no sounds, it is also not recognized by my PC as an USB device. I measured the battery voltage and it is 3.8V so it should start.
Any ideas of how to troubleshoot it?
Thank you very much
carlos
Это хороший вопрос?
1 Комментарий
Yes, I thought that the new flex could be defective, so I just tried to start the iPhone without the flex connected (in that case I would not have display but yes USB) and it didn't started.
I'll try leads 1 and 3 (I already did it, buy I'll do it again). Nevertheless, do you know any guide to troubleshoot the iPhone more deeply? So I can detect any defective chip and replace it?
Thank you very much and regards!
из mirresp
