Repair guides for Windows cell phones manufactured by Nokia.
nokia lumia1320 blank screen
I'm trying to fix a family members phone which doesnt show any picture on the screen. from what i was told the phone kept overheating when she used the GPS for a long time and it made lines show up on the screen. Apparently that went away after a few days, but after a couple of weeks the screen now doesnt turn on at all.
Anyone know how i should fix this?
Thanks.
Это хороший вопрос?
Счет 2
Добавить комментарий
3 Ответов
Выбранное решение
Try this. It should help:
Press and hold the Volume Down and Power Button down until the phone vibrates. This is about 15 seconds. You should then see the Nokia logo and the phone should restart as normal.
This is actually a very common issue for the Nokia Lumia 1320. I think it's a defect in just that model in particular. Seems to be no solution to fix this issue.
Был ли этот ответ полезен?
Счет 6
3 Комментариев:
Thanks, i tried that but it doesnt vibrate or do anything at all.
I just noticed however that when i press the power button the backlight comes on slightly, if that makes any difference.
из
It doesnt work on my lumia 1320. tried several times but my phone still on blank screen. no logo appearing when the phone vibrates.
из
It doesn’t work for me
из
1. For example, if your phone freezes or does not switch on, if an app crashes, if you have sound problems, or if the screen is blank.
2. Press and hold the Power and Volume Down keys simultaneously for 10-15 seconds.
3. Release and the phone will restart.
Счет 2
5 Комментариев:
I did that buy it only vibrates....no screen display. I made a call from anothet phone to check if it was still working...it rang but no display.
из
My Lumia 1320 only shows the Nokia logo but doesn't turn on. And my buttons are broken. It's only my power and camera button that works. And when I connect to charger it shows the Nokia logo and then the windows sign and goes back off. Due to my broken volume buttons I cannot perform a soft or hard reset. Please help asap
из
And a few days ago I put my Lumia 1320 on charge and it charged up to 100%. And I disconnected it from the charger. And the phone just went off and wont turn on
из
my lumia 1320 just switch off next thing is a symbol of setting and that of danger /phone charging what could be the problem?
из
Remove any memory card inserted and you might get rid of the problem.It worked for me
из
It sounds like the display or display connector might have been damaged due to the overheating issue. Here’s what you can try to fix the Nokia Lumia 1320 blank screen problem:
Step 1: Soft Reset
Try forcing a restart by pressing and holding the Power + Volume Down buttons for about 10-15 seconds. If the phone vibrates, wait a few seconds to see if the screen turns on.
Step 2: Check for Screen Response
Shine a flashlight on the screen at an angle. If you see faint images, the backlight might be dead, which would mean a screen replacement is needed.
Step 3: Connect to a Computer
Plug the phone into a PC and check if it's recognized by Windows. If the PC detects it, but the screen stays black, it’s likely a display issue rather than the motherboard.
Step 4: Hard Reset (if necessary)
If there's no response, try a hard reset:
  1. Turn off the phone (or hold Power + Volume Down until it vibrates).
  2. Press and hold the Volume Down button.
  3. While holding Volume Down, press the Power button briefly until you see a "!" symbol.
  4. Press the following buttons in order:
    • Volume UpVolume DownPowerVolume Down
  5. The phone should reset, but you will lose all data.
Step 5: Open the Phone & Check the Display Connector
If the phone still doesn't turn on:
  • Open the phone (you’ll need a T4/T5 screwdriver).
  • Check the display connector (near the motherboard) and reseat it.
  • If the connector looks fine, the display itself may be damaged, requiring a replacement.
Step 6: Replace the Screen
If reseating doesn’t work, you’ll need a new LCD screen for the Lumia 1320. You can find them on eBay or repair sites. Replacing it requires careful disassembly but isn’t too difficult if you follow a YouTube guide.
Счет 0
Добавьте свой ответ
jubjub532 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 68
За всё время: 9,891
