Repair guides and support for the out-of-production SUVs and trucks designed by GM-owned Hummer.
oil pressure is on 0
2008 Hummer 2 changed my oil and when i started the car the oil pressure said 0 i am looking for where the pressure sensor gauge is located. i bought on but cant find it. and not sure its the right direction
Это хороший вопрос?
Оценка 0
1 Комментарий
did you put the oil plug in when you changed the oil or the oil filter you didnt just dump what oil you put in check the level of the oil in the engine
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
When you change engine oil and filter it is normal for an engine to take a few seconds to read pressure. Assuming all was fine before you changed oil, @jimfixer has your solution. Check your oil level. If oil level and filter are fine, you need to use an obd II diagnostic machine that can read "live data" from the vehicle. It will show your oil pressure. If the sender is bad, the location depends on what engine is in your H2. Usually on the back edge of motor, just behind the intake manifold on GM engines.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
matteo siano будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 291
