Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
104вопросов Показать все
Why is vertical lines showing on it
My phone is flashing pink and grey lines going up and down on my screen
Это хороший вопрос?
Оценка 3
Комментарии:
Also facing same problem lines appear and touch did not work if press volume then work for 3 to 4 second is it hardware problem. and which replacement is original because on Aliexpres lat of LCD available.
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
It could be many things. Have you had any drops, incidents with water, or anything of the sort? Googling around, the problem seems to be fairly common. I would try to get ASUS to cover it if you can go without the phone for a bit, but if that is out of the question, you can try replacing the LCD module.
If you are in the United States, this would be a fine module:
http://www.ebay.com/itm/141758646074
The LCD and glass are fused together, but it looks like there are a few different kinds of screens out there. If possible, you should open your phone up and take a picture of the ribbon cables on the inside.
I'd also recommend buying some thin double sided tape, as shown in the guide for this device here on iFixit.
Был ли этот ответ полезен?
Оценка 1
I'm weird, that still didn't journalists who publicly written, that people with ASUS ZenFone 2 ZE551ML FLAGSHIP not only got a powerful phone, but also a massive failure of the screen :o
It's massive ASUS ZENFONE 2 ZE551ML screen flicker&vertical lines defect.
This is not a software problem, some phones came out before, but my phone, like many ZENFONE 2 users, appeared a year later.
I dare say, that this is a massive failure, not the consumer's fault, because here are some links where people complain about the same problem-existing defect on a global scale, the official ASUS ZenTalk forum YouTube and other websites:
http://www.asus.com/zentalk/thread-70061... (en)
http://www.asus.com/zentalk/thread-77523... (en)
http://www.asus.com/zentalk/in/thread-71... (en)
http://www.asus.com/zentalk/thread-12109... (en)
https://www.youtube.com/watch?v=zJTG5YYv... (rus)
https://www.youtube.com/watch?v=kRuxTefN... (en)
https://www.youtube.com/watch?v=LQRGh2UK... (en)
https://www.youtube.com/watch?v=WKHO4UkI... (en)
http://v.youku.com/v_show/id_XMTg0MTAzNz... (复制打开连接优酷视频) (cn)
http://www.asus.com/zentalk/in/search.ph... (en)
These are just a few links, and if you think otherwise, then visit the official ASUS ZenTalk forum and enter your search 'Screen flickering and vertical lines".
Оценка 0
Оценка 0
Комментарии:
can some one guide me:???????????????
из
Оценка 0
same here. bought my daughter her phone less than 2 weeks and it already has these lines!!!!
Оценка 0
Добавьте свой ответ
jcave2001 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 5,183
