Battery fully charged but will not turn on
Tab will not turn on . Depressing buttons does not work. Had back off and battery reads 4.18 volt.
Это хороший вопрос?
Это хороший вопрос?
Software has gone corrupt on the tablet most likely. Leave it on charge for longer if you haven't left it for more than 5-10 minutes.
Try charging up your tablet before performing these steps below.
Check the charger port for any blockage of dust / debris / etc. If there is, try cleaning it with a toothpick or something equivalent.
Disclaimer: You will lose all data in your internal storage on the tablet if you follow the steps below.
Steps to Factory Reset most (if not all) Samsung tablet:
Now your device should come out of the Android Boot Loop and at the first time the device will take some time to reboot.
If these steps still don't work then you may need to restore the software on your tablet via Samsung Kies. If I can remember you do it via Tools > Firmware upgrade and initialization. This will prompt you to enter the model number and the serial number of the tablet which is usually at the back of the tablet or in the battery compartment.
If the Samsung Kies method does not allow you to download the firmware for your tablet then you'll have to go to http://www.sammobile.com/firmwares/ where you type your model number of your tablet to find the firmware for your tablet . Make sure you choose latest version to the network it was mainly with.
Samfirmware instructions (After the file has finished downloading):
Был ли этот ответ полезен?
I'm dealing with the same issue. I've tried everything mentioned above but nothing's changed. Black screen and won't boot. Any other ideas?
My tablet is as good as dead, it doesn't do anything just black screen, battery reads 3.9v tried disconnecting and holding buttons down etc but nothing, ive replaced the charging port but stil no joy. I can buy a new motherboard would this fix it? Would it need the firmware loading on etc?
My tablet would not power on - battery fully charge, blank & black screen.
No combination of buttons would bring it to life.
I bought a new motherboard & when installed, the tablet came to life again.
The operating system & pre-installed apps were there, but no data.
My battery is 100% when I plug it into my computer. Won't light up. When I hit the home and power button, I hear the shutter picture.
Didn't work, I'll try to charge it overnight and see what'll happen, God bless you all
За последние 24часов: 1
За последние 7 дней: 26
За последние 30 дней: 75
За всё время: 5,115
4 Комментариев
Is it stuck on Samsung Logo at the moment?
из Ben
same thing just happened to mine
из smash8503
It just has black screen.
из Arie van den bos
good 👍🏻 thanks
из Morales Ashley
