Enable to charge the tablet!
Hi Everyone ,
First of all, sorry for my bad english !
I'm writing you regarding my tablet galaxy note 10.1 2014 version.
Since 2 weeks , I'm not enable to charge my Tablet.
Please find below the tests that I have done :
1- The tablet off : detect the charger. But doesn't charge ( after a while discharges)
2- The Tablet On : doesn't detect the charger, so it doesn't charge
- I tried more than 3 chargers that work with another tablets. Even with the PC USB it doesn't work.
Then :
1- I changed the USB connector . Model Nappe Dock Samsung Galaxy Note 10.1 for Edition 2014 SM-P600 / SM-P605 => Nothing changed.
2- I chaned teh Battery ( Original samsung). => nothing changed.
3- I tried a hard reset ( reset factory + wipe cache ...etc) => nothing changed !
I managed to charge my battery on another tablet to try if the other fonctions are ok ( Cam, Wifi, Screen, sound, display, SD Card ..etc) Everything is okay....Except the Charging part !
I have a multimeter if needed, to test the charging circuit, but I don't know how to do it, or where to test
I'm running out of ideas ! Could you please help me ?
Это хороший вопрос?
8 Комментариев
Hi Every one,
Anyone could help me on this issue please ? :(
I tried to search on the internet how to verify with a multimeter , the charging circuits, but I didn't find anything usefull ! ( not an expert in electronics ...).
is it a problem related to the motherboard ?
Thank you very much for your help !
Regards
из Hakim Kafi
I have the same problem. I did everything that you did and I am thinking it might be the motherboard. Trying to get the answer to this is not easy. Keep me posted and I will do the same
из mschievouscharm
Does the tablet draw any amps from the usb power cable? Check by set your multimeter to amperage mode and cut open only one power wire of the usb cable and stick the black probe on one and red probe on the other side.
из echow2001
Hakim! Did it work With the black charger? If so, can you link to a Picture of the charger? Would be grateful
из Jiko
Hello, no it didn't work .... :(. I ordered a black charger few months ago but nothing... I'm not sure if the one that I ordered is an original (even if it was marked " Original Samsung" ). So ... I'm still looking for a solution.
Otherwhise, do you have a link to find a real Original charger ?
Thanks guys !
из Hakim Kafi
Показать 3 больше комментариев
