3 horizontal lines with black on bottom and loose lid, fix?
When opening the lid of laptop it makes a loose crackling sound and now horizontal lines with black on the bottom of screen. Before I could wiggle the screen and it would be ok, but now black won't go away. Any help would be appreciated.
Это хороший вопрос?
3 Комментариев
I hooked up to tv and looks fine on tv. Computer screen however is weird. Black screen around and black on bottom. Does that tell you anything?
из Dorie
Your logic board seems to be OK so if you're lucky you will only have to replace the LVDS (video) cable or check the cable connection to the LCD panel and to the logic board. Be aware that the LCD panel could also be the culprit. These two parts must be tested to find the faulty one.
из lemerise
Thanks for the thoughts. I think I came up with a temporary fix for now. I just don't move or shut the lid. Put it to sleep manually and set aside till next use and she is working ok. Thanks again.
из Dorie
