When pedaling, the back tire locks.
You start to pedal and it feeels as though you just braked forward. Back tire will not turn as though chain locked up
Это хороший вопрос?
Это хороший вопрос?
Sounds like you may have a bad set of bearings. You will need to:
You are done! Congratulations.
Был ли этот ответ полезен?
URGENT HELP NEEDED PLEASE!! Hi, Im trying to reinstall a coaster wheel with the same problem,its not the bearings as the wheel was rotating forward before i took out of the frame to fix a puncture,have i maybe overtightend axle bolts (could this affect cone nuts?) or not tightened/secured brake arm enough/properly? Im a coaster brake newbie mechanic wise and its the first time ive put a coster wheel back on so would be really grateful for any advice. thanks Steve
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 38
За всё время: 18,574
1 Комментарий
when i pedal forward my chain or my back wheel wont move
из ZKWeapons
