Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110вопросов Показать все
How to get rid of the colour seeping across my phone screen?
It used to be a small spot in the top left corner
I had a green and blue patch at the corner of my phone screen. The colour only shows when the screen is on (the brighter the screen the more visible the colour) and the abnormale colouring did not show up in any screenshots. It looks like water so I put it in rice for a few days. When I took it out it had only gotten worst. The colour has now seeped across the screen and limits visibility. What should I do?
Это хороший вопрос?
Оценка 5
3 Комментариев
Did the phone actually get wet before the issue started?
из
It may have gotten wet from humidity but it was never in water
из
yup. broken LCD as it is evidenced by the appearance on the right hand top corner. Replace it to repair your display.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
@angelblais without actually seeing your screen and only going by your description, it sounds like a broken LCD. You most likely will have to replace it. Here is the guide for that. Of course, to verify this you can post some images of what your screen looks like with your original question. For that use this guide
iFixit Изображение
Инструкция
Adding images to an existing question
Сложность:
Очень просто
2 - 5 minutes
OnePlus One Display Assembly Изображение
Инструкция
OnePlus One Display Assembly Replacement
Сложность:
Модерировать
45 minutes
Был ли этот ответ полезен?
Оценка 4
You may have dropped it recently and it didn't break on the outside bit leaked on the inside
Оценка 1
I got only blue,black , violent shade on my phone corner
Оценка 0
Добавьте свой ответ
Angel blais будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 30
За последние 30 дней: 132
За всё время: 23,116
