Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1232вопросов Показать все
black screen - wont restore
Hi
this is my first post on here, but been using ifixit for a while now.
i have an iPhone 5c.
Its screen is almost constantly black and won't come on. I've tried hard reset and it seems to switch on and off whilst doing this. (you can here the ping as its recognized with USB attached). The phone does not vibrate or light up when this happens.
When i connect to iTunes, it says it detects a phone in recovery mode. So i click to update. Itunes starts doing its thing, extarcting, preparing iphone etc, the screen then comes on with the apple logo and a progress bar. But iTunes then just says 'waiting for iphone' i have left it for some time and nothing happens.
Any advice would be greatly appreciated
Dan
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Tried a force restart? If so, do you get an error code, after restoring the phone?
How to Force Restart an iPhone 5
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Tried that. It doesn't restore, so no error code. Just keeps saying waiting for iphone
из
Tried disconnecting and reconnecting the battery?
iPhone 5c Battery Replacement
из
Yes, now tried different screen, different battery, I've also disconnected the camera/proximity sensor connection, still the same
из
I have the exact problem,did you ever figure out a solution?
из
Sounds to me the LCD may be defective or broken. Try replacing the screen with a good working LCD/Digitizer and see what happens.
Оценка 0
3 Комментариев:
Thanks for your reply
The screen works during the restore, it's just not working at any other time. Could this still be the the screen that's causing this?
из
Does it keep repeatedly make the ping sounds when it's plugged in? Can be caused by a screen going faulty too.
из
No. Pings a couple of times at certain parts of the update, but then just sticks, with the apple logo and a progress bar on the screen
из
Добавьте свой ответ
Dan Hurst будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 331
