dose motor have to be pulled out to install cam bearing
Dose motor have to be out to install cam bearings
Это хороший вопрос?
по рейтингу 0
Комментарии:
@mikey00069 what exact model and year is your truck? what engine does it have?
от
Добавить комментарий
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Ответ
5.7 & 5.3 no, but i recommend it highly.
You could remove the front grill/radiator mount and possibly the bumper depending on clearance. BUT that means, radiator, oil/transmission cooler (if you have those), grill, lights, wire harness, battery removal. You can pry the mount out without removing the quarter panels and wedge it in. Just take care in doing so or you'll have to hammer out any damage you caused to them.
Im not sure about any other engines.
Был ли этот ответ полезен?
по рейтингу 0
Комментарии:
How you you get to the rear cam bearing if you don’t pull the engine?
от
Добавьте свой ответ
Mike graves будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 35
