Grinding sound won't move
My Toy Story Collection talking mr potato won't move his legs like it's supposed to and is making a grinding sound how to fix it
Это хороший вопрос?
Это хороший вопрос?
# Have fun!
Был ли этот ответ полезен?
Gearbox gear repair.
It seems to be a fundamental problem for the product.
All the problematic products are the same gear problem.
The two gears in question must be repaired by opening the gearbox.
It would be easy to get the same gear, but...
A gear is cracked.
The thickness of the steel pipe in the middle is larger than the gear hole, resulting in a crack.
Secure the cracked gear with glue and expand the hole.
Grind steel pipes to make the hunger thin.
The cracked side of the gear needs to be cut and glued. This ensures a constant gap between the teeth.
The gears were first disconnected and then polished the bumpy part of the metal pin.Cut off the cracked part a little and fix it with a force adhesive. Apply a little glue to the metal pins and fasten them with the gears.
Do you have a diagram of how the gears fit together?
@weirdalfan1 No, i have not. Cut off the cracked part of the gear. Because it is to fit each gap in the gears. This is important.
Hi there please can you help me. My mr potato head is also broken. He talks but does not wobble. Could you maybe do a step for step guide with photos on how to fix him..... im part of a toy story collection group on facebook and it seems to be a regular problem. If you could do that im sure you would help allot of people we all struggling.please please pretty please. I love my mr potato head and so badly want to fix him i have spent days trying to figure it out but havnt come right. :(
The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
@Antoinette Botha The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
Hi hi, i wanted to find out did you manage to fix your mr potato head? Mine is doing the same thing…he speaks but no longer wobbles. Please help. It must be the gears … i glued the 2 cracked gears but when i put him back together he still doesnt work.
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 1,839
1 Комментарий
Please let me know how you fixed it ???
из Antoinette Botha
