The Lenovo G570 is a 15-inch laptop announced in January 2011.
26вопросов Показать все
Can I upgrade 1600mhz ram in my Laptop instead of 1333mhz
I have a Lenovo G570 Laptop, I using 1333 MHz DDR3 RAM now I want upgrade my Ram so can I upgrade 1600mhz DDR3 ram Instead of 1333mhz ddr3 ram or can I use( 4*4) Ram one is 1333mhz DDR3 and one is 1600mhz ddr3 .
Should I use new (4*4) 1600mhz DDR3 Ram and it would be compatible for my Lenovog570.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Crucial website will have that information.
Был ли этот ответ полезен?
Оценка 1
Комментарии:
Pretty handy website. Never knew of it.
So this Laptop supports up to 1866MHz DDR3L-SODIMM RAM / memory.
из
always check the manufacturers website to see if the ram is compatible with your laptop. other then that sometimes when you use ram that is faster than what it originally had, the new ram will not perform at optimal peak and will work at a slower rate. I hope this is helpful and you are able to upgrade your ram successfully
Оценка 0
Добавьте свой ответ
sumit будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 1,118
