Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
1023вопросов Показать все
Has anyone had a successful repair with using aftermarket screen?
After replacing one of my customer's 6S plus screens, the touch ID function is no longer working. Is this a known issue with all 6S plus aftermarket screens? Please let me know if you have had a completely successful repair using an aftermarket screen on the 6S plus.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I've had plenty of success using third party vendors, from Shen Zhen. However, the times that they failed, were painful and embarrassing. Also, I couldn't promote my product as being oem quality, and i can charge more than Apple. Because I use the same parts, and repair hours faster than them
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
The only secsess I have had replacing the screen are the ones were I kept the original home button . this issue has been around since the touch ID function came out on the iphone then for a while error 53 made it even worse if you replaced the home button but that issues kinda resolved but not the fact that the only fix for the screen being broke is to rescue the original home button.
Оценка 2
Добавьте свой ответ
Chuck будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 119
