Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
48вопросов Показать все
Camera files destination problem
Any time I take a pic with my camera and then insert the Sdcard to the Pc . , it creates a new folder for the stack of pics that I taked . How can I fix it?
Это хороший вопрос?
Оценка 0
2 Комментариев
What software are you using to view the contents of the card?
из
On pc I use Windows10 . I don't know the camera software.
из
Добавить комментарий
1 ответ
Выбранное решение
Your problem has nothing to do with the camera. The camera saves your images on the SD card in folders which are named 100NIKON, 101NIKON and so forth. Image files are given a sequential number from 0000 to 9999, and only when the file number rolls around from 9999 to 0000 a new folder is created on the card.
When using a windows PC to read the card, this is the folder/file structure you should see on the card.
However, when you copy the images to the Pictures folder on your computer, Windows tries to be helpful and creates so-called virtual folders by date - which can be rather annoying if you don't want this. This behavior can be defeated: in the folder window there's a dropdown button labelled Arrange by:, set this to Folder and the virtual folders that classify your pictures by date will disappear.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Nikon D5300 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 518
