Repair and disassembly guides for GE Microwave ovens.
349вопросов Показать все
Why the lights and timers work but the unit won't turn on.
GE microwave WES1452SS1SS
My microwave just quit during a reheat. I can hear it click and the timer starts to run down, but the unit doesn't come on. Looking for some answers before I dive in. Thanks, Jon
Это хороший вопрос?
Оценка 8
4 Комментариев
I replaced surface lights in my ge space Maker xl1400 microwave An lights won't come on
из
My wall microwave timer, light, clock and turntable all work, but unit will not heat. Before calling electrician, could there be an easy fix?
из
My Walmart Rival ,Model:RGTM702 , the whole front panel will not light up ,when I open the door the light comes on, and the plate is turning slow why.?
из
My lights won’t turn on while microwave is working
из
Добавить комментарий
7 Ответов
Выбранное решение
Make sure your life insurance is paid up and there is no suicide clause in it. Because working on one of these might be considered suicide. I won't touch the inside of one like this.
Cause 1
Diode
The diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron to heat the food. If the diode burns out, the magnetron won’t receive enough voltage to operate, preventing the microwave from heating. When the diode fails, it is often visibly burned out. Inspect the diode and if the diode is burned out, replace it. If inspecting the diode proves inconclusive, test it with a multimeter that uses a 9-volt battery or put a 9-volt battery in series with the diode. When the leads are reversed, the diode should only have continuity in one direction. (Warning: The microwave oven can store a lethal amount of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the high running voltage and the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the diode.)
Cause 2
Door Switch
Most microwaves have three or four door switches. When the microwave door closes, the door switches actuate in sequence to ensure that the door is closed properly. If any of the door switches fails, the microwave will not start or heat. To determine if any of the door switches are defective, use a multimeter to test each of the switches for continuity. If any of the door switches does not have continuity, replace it. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace a door switch.)
Cause 3
Magnetron
The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the magnetron burns out, the microwave won’t heat. The magnetron is not repairable—if the magnetron is burned out, you must replace it. (Warning: The microwave oven can store a lethal amount of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the high running voltage and the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the magnetron.)
Был ли этот ответ полезен?
Оценка 10
3 Комментариев:
very good answer. although i would change the sequence..first reason can be the door switches, then diode or mag,
из
I agree check door switch first. Also, on my unit the door switches were good, but traced wires back to circuit board and tall blue box( looks like a relay ) was the problem. When I leaned it slightly one way light (and everything else) started working.
из
@longsofnor13513 I had the same problem and it was the relay. If I taped on it it would come on for about 15 seconds and then quit again.
из
I have two of these microwaves. They both had a failed relay on the control board. It is labeled Lamp Relay (RY1) on the schematic. It's inexpensive and available from electronics suppliers, such as Mouser or DigiKey. When it fails, the timer still works, but the light, fan and turntable will not work. The failure also disables the magnetron.
Note that both of the relays on the control board switch the "neutral" side of the line, but that's no guarantee that they don't have 120V on them due to some other failure, since the neutral is floating. The magnetron is controlled by these relays, plus two of the three door switches.
Never stick ANYTHING inside an open microwave cabinet without first grounding the terminals of the high voltage capacitor with a screwdriver blade. Short the terminal with the diode on it directly to the chassis ground. I then short both terminals together, just in case the transformer primary has an open circuit. You can test the filament in the magnetron and the windings of the transformer with an ohmmeter. You must disconnect the wires to do so.
Оценка 4
3 Комментариев:
Do you by chance know which part to order?
из
do not buy the relay, just harvest from a dead microwave. there are many available online recycle groups. usually a dead microwave gives u at least 2 good relays. by doing this u save money and help recycle. but do not forget safety precautions mentioned by other experts here...ur safety is worth than anything else.
из
Kinda late but this just happen to me and I thought I was screwed. Well people said check the door switch and I thought it was kinda odd the door didn’t really do anything to the display. So I decided to set the time on he unit and now it works fine. Unbelievable I know but I swear.
из
Our Viking microwave VMOS200 just suddenly quit. I was just using it and it wouldn't restart. The light came on and the timer would count down but carousel wouldn't rotate and it wouldn't start. Watched a YouTube video and found the exact situation and the repair was the micro door switch. There are four inside this model and 3 are normally open and one normally closed. Using an ohmmeter to check them to see which was faulty. All functioned normally except one which was intermittent and wouldn't work in the normally open position but would work with a slight pressure on the door open button. I replace the switch and it worked perfect. https://www.youtube.com/watch?v=_CtGVScF...
Оценка 2
2 Комментариев:
Hello rfollowell51, I have exact same issue with my VMOS200; can you share the part # that you changed?
Thanks. AJ
из
rfollowell51, thanks I set my timer and added slight pressure to my door and hit start and it actually turned on instead of clicking and counting down but not heating
из
Hello rfollowell51,
Thanks
AJ
Оценка 0
https://smile.amazon.com/gp/product/B074... I purchased this pack of 2 . exact replacement.
Оценка 0
'I have a Samsung microwave and I brought it brand new a year ago. now its not working it was working perfectly yesterday. And now this morning it not. when I plug it up the clock light and the inside light on the inside will not come on and when I open the microwave door and close the door the clock will blank on then off then thats how it will stay, is off. Can someone please tell me whats the issue sounds like I hate to throw this new microwave away I really do I'm so mad.... danggggg....
Оценка 0
Never mind it came back but yea is the door switches or the hings. I bet me or my son hangs on it a little when we shut it without realizing it.
Оценка 0
Добавьте свой ответ
Jon Ziegler будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 128
За последние 30 дней: 500
За всё время: 151,929
