The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Вопросов 20 Показать все
metal casing bend, applying pressure on screen
in one way or another, my upper casing which covers the macbook retina screen has a bend in the corner.
This applies pressure on the screen, and it changes color in that specific corner.
Is it possible to take the bend out of this with some force, or do I need to take the whole screen apart so I can only apply pressure on the metal and than reassemble everything?
If I manually pull the screen a little backwards, the yellow glow is gone and the problem is solved...
See these pictures:
https://www.dropbox.com/s/tnbxpt9p2czbl1...
https://www.dropbox.com/s/c7v2961ctl39g1...
Any advice would be highly appreciated!
Pieter-Jan
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Ouch! Sorry guy its time for a new display assembly ;-{
The problem here is unless you take the display off and then take it apart to just have the metal shell it won't be easy to bend the cover back without needing to press the tool across the glass which will damage the LCD or break it. These displays are not easy to take apart, and you'll likely damage the components in the process which are not available discreetly from Apple. You might be able to find a used display for less on eBay. Just be careful how you pay and make sure they offer a return policy.
Here is the IFIXIT guide you'll need to follow and the needed part:
Replace a display compatible with the model A1502 Early 2015 13" MacBook Pro laptop. Includes the 2560 x 1600 13.3" Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, Wi-Fi antenna, camera, and display data cables. Part #661-02360. Изображение
Продукт
MacBook Pro 13" Retina (Early 2015) Display Assembly
$449.99
Был ли этот ответ полезен?
Оценка 2
Pieter-Jan, I would suggest disassembly is required as if you apply any pressure to the screen it will more thank likely crack. Once you have fixed the dent the problem should be fixed.
Оценка 0
2 Комментариев:
I'm afraid of disassembling the screen, I have read the chance of breaking it is more than likely.
I was not planning to put pressure on the screen, just try to bend the metal behind the screen from the side?
but this would work indeed much better if the metal was loose from the screen itself....
And is the reassembly quite easy to do? I think it might be tricky as well with the rubber on the side, my guess is I won't be able to reassemble everything as Original...
experience with this?
thanks a lot for your comment!
Pieter-Jan
из
If you are careful and follow the guide's you will be successful, you need the metal to be loose to have any success with this as if you apply any pressure while it is still assembled, to the bend the metal shell you will highly likely break the screen (even from the side).
The disassembly is not made easy but the process is quite straight forward, and as iFixit have the guide use it to help you, I have repaired a lot of varying device screens and if you keep it organised and are vary careful with it you can repair this fault.
If you are still worried about the potential of breaking it, you may need/want to take it to a repair vendor with experience in this model of device.
из
Добавьте свой ответ
pieterjandhondt будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 2,634
