The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
What is the best epoxy for broken screen
I have this crack on my samsung:
I would like to put a glue to avoid the glass to break anymore,
Do you have any suggestions?
I'm planning to put a plastic cover as well, but first i want to ensure the glass won't keep cracking
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Once the glass has cracks, it has weaknesses. There's not really any cure for this. Any sort of adhesive you use is really just going to keep the pieces from moving much or falling out. I have seen people apply clear packing tape with the intention of continuing to use the device since it still worked fine, and if the cracks got worse or further physical damage happened that rendered the screen non-functioning (in this case you might lose touch response), they'd go ahead and replace the glass. Really, any choice outside of full repair of the damaged part is just a band-aid.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
alvarolloret буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 17
За всё время: 9,948
