Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
65вопросов Показать все
dvd drive will not stay closed
the dvd drive on my clamshell ibook would not open. I used a paperclip to release it, but now the drive will not click and stay shut. the drive works, will play store bought dvds. Can this be repaired or does the drive need to be replaced
Thanks David
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi,
I am trying to fix a clamshell ibook that has the same problem (drive works but it does not stay shut).
In my case, I think the plastic "thing" (that used to close the tray) is broken.
Since spare parts are very (very! :-) ) difficult to find nowadays, does anybody know if I have to replace the whole drive or only the bezel?
I cannot make out where exactly the "click" that makes the drive stay shut should takes place.
Thanks
Olivier
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
The opening mechanism may have stuck when you placed the paper clip in it forcing it to stay open. Try using the clip several times to see if you can get it to release.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Добавьте свой ответ
David Brannon будет вечно благодарен.
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 686
