Outer glass panel replacement also need full disassemble?
I like this guide as it is crystal clear: MacBook Pro 15" Unibody Mid 2009 LCD Replacement
However, I have a question:
The model is A1286 Macbook pro 15".
The outer glass panel is broken while the inside LCD still works well.
Can I just lift(disassemble like the guide) the outer glass panel and replace with a new one?
Do I need to follow all the procedures? Thanks for your time.
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Don't do anymore than you need to.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Agreed +
из
well it took me 20 minuters to remove the panel and put on the new one.
Just use a knife to strip the panel off, nothing else.
Thanks for all the replies.
Оценка 0
1 Комментарий:
glad to help
из
I need to order an outer glass panel for my 15inch MAcbook pro. Does anyone know where I could order this and how much it costs?
Оценка 0
Добавьте свой ответ
longlens будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,724
