airport extreme card removal
I removed the battery and there is no door too flip open to get at the airport extreme card. Is it possible that I have a different or older version? My model number is M9676LL/A
Update
wow that looks like alot of hard work. let me ask this question first. my powerbook has only two networks listed in my airport network list whereas my girll friends macbook has more than 20. Any thoughts?
Update
Hey David! I just wanted to say thanks for the help. I bought a Hawking usb wireless adaptor and it blows away my airport extreme card by leaps and bounds. I also maxed out my ram so I am a happy camper until I can afford a new macbook pro. Thanks again!!!
Это хороший вопрос?
Оценка 1
3 Комментариев
She probably lives in a dorm and you don't.
из
Are you guys are in the same place and this is occurring? If I recall correctly, older Airport cards don't work with newer "n" networks. I could be way wrong on that, which is why I'm only posting this as a comment.
из
Yes the two laptops are side by side. I appreciate any advice you have to offer.
из
Добавить комментарий
1 ответ
Выбранное решение
Your M9676LL/A is model A1106, which is a different device than the one you originally linked to. Here's the device page and guide that you will find more helpful. I'll change the device that the question is linked to as well. Unfortunately, replacing the Airport Extreme card in your model is quite a bit more difficult.
Update
So I'm going to stick with my answer that your PowerBook has an older wireless card in it, so that's why you don't recognize the additional networks. Replacing your Airport Extreme card with a newer one with 802.11n capabilities would probably fix this, but it might also be worth your time and money to see if there are any USB devices that will help. I'll do a quick check.
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
+ good answer
из
+ makes sense to me
из
Добавьте свой ответ
jaff будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,222
