Second generation (E30) BMW 3 Series and the final 3 Series to sport the boxy '80s styling similar to the E32 7 Series and E34 5 Series.
12вопросов Показать все
When should timing belt be changed
At how many miles should belt be changed.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Hi there and not sure if you got your question already answered or even still need it to be answered :) What I seem to remember is that the M10 318 and 318 ('84-'87) has a chain, the M40 318 and 316 ('88-'91 & not many in the US) has a belt.
E36 = M50 = timing chain. E30 = M20 =timing belt
Although you did not specify the year, model, and engine size, here are some general guidelines:
All the 4 cylinder BMW 3-series (318i, 320i) had a timing chain.
From 1984 to 1991, the 6 cyl (325 series) had a timing belt.
From 1992 and up, the 6 cyl (323, 325, 328, 335 series) had a timing chain.
If the BMW you are inquiring about should have a timing belt, BMW recommends to change it every 60,000 miles.
Hope this helps a little.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
+ Agreed
из
it is my understanding since having a honda (belt) and moving to a jeep (chain) I have been told about this kind of issue. If you have a timing belt and the timing belt goes you can crack the head or bend a couple of valves, so depending on the mileage, better to do it if you are not sure its been done. Otherwise unless your crazy lucky a valve job + new valve stem seals while you there etc etc....I don't know about much about BMW's but i think it's the same kind of deal.
из
the e30 320i had a timing belt and was a 6 cylinder m20 engine
из
Добавьте свой ответ
lsaunders будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 6,764
