My keyboard is disappearing while typing How do I Fix it
My key bOard iS disappearing while tyPing
Это хороший вопрос?
Это хороший вопрос?
Go to settings>>application manager>>all and find the keyboard you are using, whether it is the Google stock keyboard or a third party one like SwiftKey etc, clear the data and try again. Failing that, install a third party keyboard and see if the problem persists
Был ли этот ответ полезен?
Thank you! It really works!
My keyboard keeps disappearing text when ever am typing how can I fixed it please
Same issue with my S6, it only started after installing the latest update. Have tried resetting the keyboard and rebooting the phone, but no joy .
Since the update, also can't watch videos - especially on FB app - it will play for a few seconds then pause. Have also tried uninstalling and reinstalling the app, but problem is still there.
Did you ever manage to fix this having the exact same problem as you i am also on an s6 .. keyboard probs and the video pausing problems also
my phone too... i don't know why...
but i have the same symptom as yours.
but mine not samsung, it's Vernee X 6/128.
(keyboard hides in the middle of typing, playing vids on fb & other apps keeps pausing on it's own.)
TF happen? anyone have solution?
My Galaxy S6 just started doing the same thing; keyboard minimizes and videos, especially FB, stop and start. I just had my battery replaced.
Anyone with an answer for us would be greatly appreciated
I've discovered a couple additional related issues. Not only does PLAYING videos on FB a problem, but now also I see TAKING video with my phone's camera had the same symptom: start recording and a second or two later the recording stops. I downloaded the GO keyboard app, but the same thing happens with it. I've cleared the cache, but the problem returns in a few mins.
I'm considering Resetting my phone to factory settings to see if that solves it. A friend suggested that perhaps a cable may be loose. It does act similar to if I'm hitting the Back button.
When I try to type something long in facebook or instagram my keyboard dissappear itself..problem in video playing in youtube app
i have the same problem my keyboard keeps disappearing . i have tried 3 other third party keyboards and the same thing happens . must be the phone samsung s6 ? but i have seen the same problem on here with other phones and tablets . What is causing the problem ?
i found this on another page..
I had a similar issue but did not have the third party app you mentioned installed. I was able to fix the issue by going into Settings>My Device>Language and input>Samsung keyboard, clicking on the settings icon and "Reset Settings". This reset the personalized keyboard settings (I have not noticed a difference in anything) and the disappearing keyboard issue has not been an issue since!
It's definitely NOT just "a Samsung s6 thing".
My BLU Studio XL2 does it and I had a Sprint evo3D that did it too.
After updating different apps in March 2018, i noticed that my keyboard was disappearing while typing and also had a drainage issue. I looked at which app seemed to be problematic (ended up being the Xperia Clock) which i uninstalled. For the keyboard, the only thing i did after resetting the keyboard (which did not resolved the issue) was to change the dictionary and language for "English US". Everywhere in my settings where Canada English was shown, i changed it to US English and so far, it has been two days that my keyboard seemed to be staying while typing! The only reason i found out about the dictionary issue was simply by reading various post and gave it a try.
Hi there,
I have had the same issue, on my old Nexus 5x. Disabling all the keyboards expect of one that you want to use did the trick for me.
Regards,
Yarik
give me give me keyboard on this phone please provide nice I can't type where is the keyboard
I have the same problem. I tried both switch key and go keyboard apps and still have the problem. Is there another trick?
Thanks
I tried these things, but I found a fix; at least for Instagram. Go into Apps>Application Manager>Instagram (or whatever you're having the problem with)>FORCE STOP, then go into Storage and 'Clear Data'. You'll have to sign into your app again, but it seems to fix it.
Seems to have a short term effect
Dictionary issue. Setting it to US seemed to solve the issue.
I finally found what fixed this problem on my device.
in the device main settings , click/ "language and input, then/ Gboard, then / preferences, then / unclick "popup on keypress"
I also unclicked "show emojis in symbols keyboard"
The keyboard hasn't dropped since!
Finally I have found the solution. it was from Clean Master & Super Cleaner apps I had to stop them from working in the background and now every thing is working well.
I was about to sell my phone as I did all the ways to trying to solve this issue.
I hope this will work with you guys.
Tried all of the above on Galaxy Note9. Only, and I say Only, uninstalling apps by order of download works. Make a list. App 1, no change, App 2, no change, and so on. For me, it was the 11th app recently installed (this can include updates) so turn auto update off. My Note is back to normal after 2 weeks of BS.
Go to settings, advance features, turn on “ smart stay” After doing this I can use Samsung original or Gboard keyboards. I also have on one-handed mode clicked on.
what is the green box on my typing keys on my android phone
Finally works. 1st go to setting>language>default keyboard: change to another option (mine is huawei swype), once changed, now your keyboard is back but its in huawei swype version,
Now go to google play install or update new Gboard. Once done change back your keyboard to Gboard.
And done !
I was having the same issue, but my fb videos would randomly pause, youtube would back out, and even snapchat would cut out. After I tried EVERYTHING, I was thinking maybe it's an app that's causing it, for some reason I had two Pintrest apps on my phone, I dont know how but I uninstalled both of them and now my phone works with fb, YouTube, snap, and my keyboard doesnt disappear every 15 seconds. Hope this helps someone!!!
I had this problem and to fix it I went to my settings and switched my keyboard to left handed keyboard and it fixed the problem
It happends kinda daily but it’s a easy fix just open setting or press you power button and press restart
My keyboard was disappearing in facebook when I typed more than two words. I went to settings, general management, language and input, on screen keyboard and selected default keyboard samsung. Problem fixed on my Samsung tablet.
I installed avast antivirus and my problem was fixed
Well if your using a keyboard app for example kikakeyboard is a keyboard app well try to clean your storage and delete several of your apps and maybe even restart your phone and then let it cool down for a couple of minutes or hours or if none of this works than you delete the app thats causing this and than try to install the app again or just don't use this keyboard also I'm talking about a phone I don't know much about laptops or chrimbooks or computers sry and please subscribe to •lazy bean 0-0• if this helped you have a great day and sorry of this did not help you but I hope it does help you toodles!
I do not see mic on key bord.my email adhanglesudhakar5@gmail.com
Voice typing mic
За последние 24часов: 3
За последние 7 дней: 17
За последние 30 дней: 88
За всё время: 116,357
9 Комментариев
jmy
\k,eygbosxrdc
\isxhnt
\work,ihngb
\properl.y
из Anne Page
My administrator has changed from Trish to Carol
из Trish Cavanaugh
how come there is no answer to this issue
из tom kennedy
I don't know. But, strangely, I switched back to SwiftKey Keyboard, and I haven't had any problems. Very strange...I've been posting on Instagram a LOT more, and haven't had an issue now. I did clear out the cache by pressing the power (right), 'home' and 'volume down' buttons on restart (brings up green code commands), but that was a while ago. Just glad it seems to be ok.
из Priyagold
I have only had the S6 4 days & the same problem...disappearing keyboard, no editing for videos or photos. I am very agitated!!!!!
из Kitty Parsons
Показать 4 больше комментариев
