I can't download my pictures to my computer
Problems downloading images to computer.
When I connect the camera to computer via a USB cable it does not register on computer (I don't get the alert sound), hence I can't do anything.
Это хороший вопрос?
Оценка 2
1 Комментарий
What is your computer Windows or Mac?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Have you tried a new cable as well as a different USB port on the system? Is your camera able to charge via the USB connection? If not I suspect the cable is bad.
While not as easy as plugging in your camera, you can take the memory stick out of your camera and use a Sony memory stick to USB adapter which is connected to your computer.
Был ли этот ответ полезен?
Оценка 1
Please check the connection of the USB-ports. Maybe your USB-output/input doesn't work correctly.
Ich hoffe,ich konnte ihnen helfen.
Оценка 0
Добавьте свой ответ
ROBERT SAVAGE будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 746
