Remove screw ?
I'm on step 3 of the instructions for installing a new hard drive in my Powerbook G4 15" 1.5-1.67 GHz. One of the 2 12 mm Phillips screws in the memory compartment won't budge. Any suggestions ? Thanks !
Это хороший вопрос?
Это хороший вопрос?
Stuck screws are very frustrating!
Don't just torque on it blindly, as stripping the screw will leave you in a very poor state.
Try briefly using a hair dryer on the area to loosen things up (don't point the heat at the logic board for long, though!).
Then, with the CORRECT screwdriver size (#00), push firmly down directly into the screw and, while pushing down, turn the screwdriver.
The downward force ensures maximum drive to screw connection, and minimizes stripping.
I hope this helps!
Был ли этот ответ полезен?
use a magnetic screwdriver. Make sure you have the right size too.
Or get someone strong to have a go!
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,404
