The Samsung Galaxy Core Prime Duos Android phone is a variant of the Samsung Galaxy Core Prime line. Model number SM-G360H/DS (SM-G360H/Dual-Sim). Released in November 2014.
Fell in water samsung core prime
Hi i accidentally dropped my phone into the river when i was fishing i put it to dry as soon as possible didnt turn it on until the next day it turns on and the screen boots up and everything is normal except that when it gets to the lock screen i touch the screen but nothing happens i cant slide the screen open or anything. Please help
Это хороший вопрос?
Счет 8
1 Комментарий
I played with it in the bath - worked fine but then I stopped to let it dry so same problem as you
из
Добавить комментарий
1 ответ
Выбранное решение
Hi Kimberly,
you are experiencing the after effects of water damage. Unfortunately repairing your phone to get it up and running again would cost more than what the phone is worth.
If there is data stored on the phone that is irreplaceable then it may be worth it to you but the phone itself should be considered a write off.
If you drop your phone in water again here are some tips about what you should do
1. Do Take your battery out
2. Do NOT plug it into a charger
3. DO NOT attempt turn it on
4. Do NOT leave it to dry, put it in Rice/Silica gel or use a hair dryer on it. Water itself is not harmful to electronics, its the minerals in the water. So by leaving it out to dry you are only allowing the minerals to bake onto the board.
5. DO Wash it out in distilled water, give it a good 2-3 minute wash in distilled water to displace all the bad water before it deposits it's minerals on the board. Once it's deposited them, your options become very limited.
6. if you don't want to wash it out, take it to a repair shop who does micro soldering ASAP (While wet is best) and they will bring it back to life for you. They will possibly charge you less because you did the right thing too (I know we do)
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Okay thank you
из
Добавьте свой ответ
[deleted] буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 38
За всё время: 4,554
