The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202вопросов Показать все
Rear camera's and flashlight not working
At first the camera app would just shut down, so of course I restarted the phone. Then the camera app was working but it was fixed in selfie mode. I was not able to use the rear camera or the flash light. The rest of the phone is working just fine but I can't access the rear camera of the phone in apps either.
When I press the four circle icon the the camera app, it allows me to choose between the selfie cam (This one is selected) and adding a camera. When I choose to add a camera I get the option to add photo booth.
I already tried to restore the default camera setting but it didn't help.
Это хороший вопрос?
Оценка 6
5 Комментариев
same problem here!!
please help!
i am going to order a new camera and replace it than let s see what happens.
из
Same problem please help me
из
restart your camera and immediately open cam, it will work, htc having overheating issue in 816 desire too
из
Even my m9 plus has the same issue.Again it happened on the M7 and M8 I had before.Infact from now even if the HTC is $1,I can't but HTC any more.
из
so my htc one e8 have same problem , did one of u guys fix it???and how?? please answer and help me
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Sir I have a same prblm flash and rear camera nt working how can get back my camera help me
Был ли этот ответ полезен?
Оценка 1
It is a hardware issue with the camera itself. Its a very easy repair to do. Order a replacement camera and you should be able to swap it in a matter of minutes. Because iFixit rocks, there is already a very detailed thread on this:
How to Replace Rear Camera Module?
Оценка 0
htc d820n back cemra option is no hilighted
Оценка 0
Добавьте свой ответ
Frank Vlaar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 11
За всё время: 11,133
