Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Pentalobe screws just spinning!
Hello
Recently repaired a friends iPhones 5s. Initially was getting no service after repair and updating iOS appeared to resolve. Then phone died when testing, though all appeared okay so popped on charge.
After changing, received the reboot and blue screen of death. Attempted to update iOS via iTunes to no avail.
Assume two of the screws on the top right panel are wrong way round. Problem is the two pentalobe screws now won't come out - they're just spinning in place! I'm relatively sure that if we got those back out we could swap the screws back and all would be fine but just stuck at this point.
Has anyone had any similar problems with the pentalobes and if so, what did you do? Not keen on drilling as never done before but might have to at this rate!
Thanks in advance for any advice!
Cheers, J.
Это хороший вопрос?
Оценка 2
2 Комментариев
Hi Dc
Thanks for the response! In upward pressure, do you mean away from the screen? Sorry just wanted to clarify!
Thanks, J.
из
Yes upward pressure on the screen, so if the phone was flat on a table pulling straight up on the screen with the suction cup, and that will allow those screws to come out.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I've seen this in the past, you need to apply upward pressure on the screen. Using a suction cup pull up on the screen and then try to turn those screws out.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jake будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,123
