iPhone 6 battery has burst and is leaking
So I've got my friends iPhone 6 here, he said its no longer charging so we got a new replacement lightning port. I've just opened it up however to find this...
Looks to me like the battery has burst and started leaking for some reason. I've never encountered this before and was wandering if anyone else might have some thoughts on it?
Do you think we should just be able to replace the battery and get it working again?
Это хороший вопрос?
3 Комментариев
I have repaired a few phones with this issue and the common outcome is the battery acid has reached logic board causing unreserveable damage. Before going out and buying a new battery try just finding a used old one to do a test run with. Phones with logic board damage from acid will not want to turn on and off with ease. I most commonly seen them turn on with Apple logo and then phone will just have blacklight on with no display.
из Ryan
Hope I get an answer so this friend got an issue with te batt going to full batt into empty in a couple of minutes then he said to me that the phone no longer turned on so I ordered a new batt and when I replace it I found that the old one was very inflated and after I put the new one happened the same thing you are mentioning apple logo then phone in black light with nothing in the screen.. do you recomend to try it again with a new batt or is the logic board and that's it... thanks in advance
из Erick Leyva
ouch!!!
из Vinicius Lupas
