GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152вопросов Показать все
Why can't I get a display
I recently replaced my iPad 2 digitizer and even thought with a bad digitized I still got a working screen with light so now that I replaced it I'm not getting a screen I would do a hard reset but there's no way of knowing the home button is working since it has no cords attached to it or anything I'm really stuck here please help but I know it's on cause if I plug in the charger I'll get the charging sound
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
I would double check your LCD connections. It sounds you have a loose connector not making good contact. But make sure you power down the device or disconnect the battery before checking your connections you don't won't to short anything out.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
I let the battery die down and when I plugged in the charge the battery sign comes up like when it's dead so I know it's not the lcd so I let it charge but it seems now it will still not show the screen but I plugged the charger in again and I can hear the charging sound I'm not sure what to do please help
из
After you let it charge do you see any image on the screen? if not during your iPad repair the blacklight components could of burnt out just by what you're describing.
из
I think im having the same problem. While charging a dead battery the screen is bright and functional. However it goes completely black, no activity at all, after booting. Any ideas?
Оценка 0
Добавьте свой ответ
lateef ambali будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 93
