Replacing turn signal/wiper/cruise control combination switch
I have the replacement parts, but need some information in replacing the old one.
Это хороший вопрос?
Это хороший вопрос?
Simply pull off the rubber cover, using a flat screw driver to help if needed. You will then see a bolt that holds the assembly in place, and a few screws that hold on wires. Remove those, and then unplug the wire harness plug. With all that done you should be able to pull out the old switch. Installing the new switch is just the reverse of this.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 623
