Модель A1312 / Середина 2010 г. / 3,2 ГГц Core i3 или 2,8 и 3,6 ГГц Core i5, или 2,93 ГГц Core i7, ID iMac11,3
Broken LCD temp sensor connector on logic board
I own mid-2010 27” iMac
While attempting to do the HDD swap, I broke the LCD temp port that's attached to the logic board, and now the cable doesn't connect properly. As a result, the fan is going maximum. The sensor cable is fine, it's that port on the logic board that's broken.
What's the part number for this part and what would be the best way to fix this?
Это хороший вопрос?
Счет 1
2 Комментариев:
Please post picture of damaged area.
из
I will later tonight, but the connector on the logic board is broken, I accidentally pulled it while I was trying to remove the lcd panel. I think the cable is fine, but the connector is broken and the pin won't sit properly.
из
Добавить комментарий
2 Ответов
You might try just soldering the wires directly back onto the board. That should make things work again simply.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Yes, I'm gonna try that but I need to buy the replacement part because mine is broken.
из
@jiwoongyou I am certain you have this fixed by now. Answering this just for completion sake. That particular connector is a Molex 53261-8602.
Счет 0
Добавьте свой ответ
Ji Woong You буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 3,977
