Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87вопросов Показать все
I have to mess with the gear shifter while starting it? Why
I couldn't start my car, after putting it on a battery charger it started. It didn't work with regular jumper cables and vehicle. So I bought a new battery, still didn't start, I mess with the gear $@$* pushing it forward ( it is an automatic ) and holding it their while I try starting it, and it works. But why, why is it doing it how can I fix it and what caused it?
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Will the car start in neutral? If it does then @oldturkey03 is probably right but you may also want to check the shift lock as this can also cause problems when starting
Был ли этот ответ полезен?
Оценка 2
@marshajo13 when you say pushing it forward, do you mean further into the "P" position? It does sound like a bad or misaligned neutral switch, You'll have to check it out. The switch is located in the central console. It is number 2 in the drawing.
Оценка 1
Добавьте свой ответ
Marsha Sanchez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 416
