Can I use early 2015's battery on a late 2013 model?
I'd like to know if is it possible to use early 2015's battery on a late 2013 model, and if anyone already did it
Это хороший вопрос?
Это хороший вопрос?
The 2015 MacBook Pro Retina uses an A1582 battery
Compatibility
Models Model Numbers
MacBook Pro 15.4" 2.2GHz Core i7 (A1398) - Mid 2015 MJLQ2LL/A
MacBook Pro 15.4" 2.5GHz Core i7 (A1398) - Mid 2015 MJLQ2LL/A
MJLT2LL/A
MacBook Pro 15.4" 2.8GHz Core i7 (A1398) - Mid 2015 MJLQ2LL/A
MJLT2LL/A
The 2013 MacBook Pro Retina uses an A1493 battery
Compatibility
MacBook Pro 13" Retina Display Late 2013
2.4 GHz (Late 2013)
2.6 GHz (Late 2013)
2.8 GHz (Late 2013)
MacBook Pro 13" Retina Display Mid 2014
2.6 GHz (Mid 2014)
2.8 GHz (Mid 2014)
3.0 GHz (Mid 2014)
Был ли этот ответ полезен?
Will it fit though? They look identical.
They look similar but far from identical. Look at the width of the outer modules.
have installed A1582 battery to MacBook Pro 13" Retina Display Late 2013
- no issue, and hold a charge
tried it, it seems to be OK but when you stress CPU and GPU when on battery only (no charger) than it tends to shutdown (hard)
So, NOT COMPATIBLE
The answer is *almost* helpful. It does 15" for 2015 and 13" for 2013. But what about compatability between 2013 and 2015 15" ? In 2017, Apple replaced the battery in my late-2013 15" Retina, and 18 months later that battery started swelling a little - now swollen enough to pop the flap at the back hinge.
Hi
i just install A1493 Battery To Macbook Pro 13 Retina 2015 Was No Problem Charging And Discharging
Original Battery Was A1582
so A1493 and A1582 Compatible
Well give it a month and tell us then.
This still hold true?
So, NOT COMPATIBLE
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 31
За всё время: 2,438
